跳转到主内容
Unbranded UB-15MS10 Back Camera Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Unbranded UB-15MS10 Back Camera Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the cover over the Micro SD outlet by using a plastic opening tool to pry open and push out the cover panel.
  2. Unbranded UB-15MS10 Back Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the two 4-mm #0 screws from the inside of the Micro SD compartment.
  3. Unbranded UB-15MS10 Back Camera Replacement: 步骤 3 中的图像 1,2 Unbranded UB-15MS10 Back Camera Replacement: 步骤 3 中的图像 2,2
    • Insert blue guitar picks in the crease between the top and bottom panels starting on the same end as the Micro SD slot.
    • Inserting the picks directly under the Micro SD compartment was the easiest place to get started. It still requires some force.
  4. Unbranded UB-15MS10 Back Camera Replacement: 步骤 4 中的图像 1,1
    • Insert the black spudger between the guitar picks in order to pry open gaps between the blue guitar picks.
    • As the gaps open, slide the guitar picks along the sides to separate the panels.
  5. Unbranded UB-15MS10 Back Camera Replacement: 步骤 5 中的图像 1,1
    • Pry all four sides apart using the blue guitar picks and the black spudger until they can easily be pried apart by hand.
  6. Unbranded UB-15MS10 Back Camera Replacement, Back Camera: 步骤 6 中的图像 1,1
    • Remove the small piece of black tape.
  7. Unbranded UB-15MS10 Back Camera Replacement: 步骤 7 中的图像 1,1
    • Remove the black 4-mm #0 screw.
  8. Unbranded UB-15MS10 Back Camera Replacement: 步骤 8 中的图像 1,1
    • To finish removing the camera, disconnect the camera ribbon from the white ZIF connector on the motherboard.
    • There are two very small prongs on the side which need to be pushed towards the center of the connector to remove it.
结论
4等其他人完成本指南。
Jordan Turk
于09/21/15注册
331 声望
创作了2篇指南
团队
IUPUI, Team 2-1, Baechle Fall 2015 IUPUI, Team 2-1, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S2G1
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 707
