跳转到主内容
Umbrella Stretcher to Rib Joint Repair
你所需要的
  1. Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: 步骤 1 中的图像 1,2 Umbrella Stretcher to Rib Joint Repair, Umbrella Stretcher to Rib Joint Repair: 步骤 1 中的图像 2,2
    • Take the broken part of the stretcher to rib joint.
    • Realign it with the rib assembly.
  2. Umbrella Stretcher to Rib Joint Repair: 步骤 2 中的图像 1,1
    • Take the needle and carefully pass it through one of the holes as seen in the picture.
    • Then pull it back to the same side you went through.
  3. Umbrella Stretcher to Rib Joint Repair: 步骤 3 中的图像 1,1
    • Take the needle and pass it under the stretcher (not through the middle).
  4. Umbrella Stretcher to Rib Joint Repair: 步骤 4 中的图像 1,1
    • Position the needle so that it faces the second hole from the same side you just went through in step 3.
    • Take the needle and pass it through the second hole.
    • Then position the needle so that it faces the first hole from the same side you just went through.
  5. Umbrella Stretcher to Rib Joint Repair: 步骤 5 中的图像 1,2 Umbrella Stretcher to Rib Joint Repair: 步骤 5 中的图像 2,2
    • Repeat steps 2-4 until the two pieces are held tightly together.
    • Tie a knot to secure it.
    • Refer to step six if the rib punctured the canopy.
  6. Umbrella Stretcher to Rib Joint Repair: 步骤 6 中的图像 1,2 Umbrella Stretcher to Rib Joint Repair: 步骤 6 中的图像 2,2
    • It is easier to sew when the canopy is closed
    • Take the hole, hold each end and pull outward into a line.
    • Make sure that it is in line with the umbrella canopy seam.
    • Take the needle and thread and form a hemming stitch (see Step 7).
  7. Umbrella Stretcher to Rib Joint Repair: 步骤 7 中的图像 1,3 Umbrella Stretcher to Rib Joint Repair: 步骤 7 中的图像 2,3 Umbrella Stretcher to Rib Joint Repair: 步骤 7 中的图像 3,3
    • Begin with a threaded needle and start the stitch at one end of the hole and pull the needle all the way until just before the thread runs out.
    • Then loop back around and go through again.
    • Repeat until you reach the other end.
    • You can form the stitch multiple times to make it more secure.
结论
The umbrella is fixed now, you may now use the umbrella freely.
2等其他人完成本指南。
Rodrigo Soliva
于10/26/17注册
182 声望
撰写一个指南
团队
2条评论
I have a problem with the auto lock, it's a knight bridge umbrella, when i retract it, it doesn't lock in place, can it be fixed or replace the handle in case it's totally eroded?
kamec 01 - 回复
I have 2 umbrellas which have both snapped at the hole. Is there a way this technique or a version of it can be used to repair them?
Jenny - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 36
过去 30 天: 199
总计 12,077
