跳转到主内容
加入维修社区 - 创建账户
本拆机指南正在进行中 – 定期刷新以看到更新!
  1. Ultrasonic Aroma Diffuser, display: 步骤 1 中的图像 1,3 Ultrasonic Aroma Diffuser, display: 步骤 1 中的图像 2,3 Ultrasonic Aroma Diffuser, display: 步骤 1 中的图像 3,3
    • This is a display of the shell of Ultrasonic Aroma Diffuser and the internal water tank and bottom structure.
  2. Ultrasonic Aroma Diffuser, Disassemble the basc: 步骤 2 中的图像 1,2 Ultrasonic Aroma Diffuser, Disassemble the basc: 步骤 2 中的图像 2,2
    • Remove the three screws at the bottom separately and pull them open the bottom to reveal the internal structure.
  3. Ultrasonic Aroma Diffuser, Remove the button assembly: 步骤 3 中的图像 1,3 Ultrasonic Aroma Diffuser, Remove the button assembly: 步骤 3 中的图像 2,3 Ultrasonic Aroma Diffuser, Remove the button assembly: 步骤 3 中的图像 3,3
    • Remove the two button assembly for the control device on the internal Tactile Switch
  4. Ultrasonic Aroma Diffuser, Remove the DC cooling fan: 步骤 4 中的图像 1,3 Ultrasonic Aroma Diffuser, Remove the DC cooling fan: 步骤 4 中的图像 2,3 Ultrasonic Aroma Diffuser, Remove the DC cooling fan: 步骤 4 中的图像 3,3
    • After removing the button assembly, remove the four screws used to fix the DC cooling fan at the bottom, and then remove the DC cooling fan.
  5. Ultrasonic Aroma Diffuser, Remove the white box: 步骤 5 中的图像 1,3 Ultrasonic Aroma Diffuser, Remove the white box: 步骤 5 中的图像 2,3 Ultrasonic Aroma Diffuser, Remove the white box: 步骤 5 中的图像 3,3
    • After removing the DC cooling fan, remove the screws of the small white box next to it and remove the small white box.
  6. Ultrasonic Aroma Diffuser, Remove the DC power connector: 步骤 6 中的图像 1,1
    • After removing the small white box, remove the internal DC power connector.
  7. Ultrasonic Aroma Diffuser, Remove the PCB: 步骤 7 中的图像 1,3 Ultrasonic Aroma Diffuser, Remove the PCB: 步骤 7 中的图像 2,3 Ultrasonic Aroma Diffuser, Remove the PCB: 步骤 7 中的图像 3,3
    • After removing the DC power connector, remove the screws fixing the PCB, and then take out the PCB.
  8. Ultrasonic Aroma Diffuser, Remove the circular PCB: 步骤 8 中的图像 1,3 Ultrasonic Aroma Diffuser, Remove the circular PCB: 步骤 8 中的图像 2,3 Ultrasonic Aroma Diffuser, Remove the circular PCB: 步骤 8 中的图像 3,3
    • After disassembling the internal structure of the base, start disassembling the internal structure of the middle frame. Remove the screws of the circular PCB inside the middle frame, and then take out the circular PCB.
  9. Ultrasonic Aroma Diffuser, Remove the sealing gasket: 步骤 9 中的图像 1,3 Ultrasonic Aroma Diffuser, Remove the sealing gasket: 步骤 9 中的图像 2,3 Ultrasonic Aroma Diffuser, Remove the sealing gasket: 步骤 9 中的图像 3,3
    • This is the final step to separate the outer shell from the internal structure. Remove the sealing gasket installed under the water tank by unscrewing the three screws on it. Once the sealing gasket is taken off, the entire internal structure will be completely separated from the outer shell.
siyuan long
于03/22/25注册
169 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 46
