简介
Use this guide to replace a damaged mesh covering that surrounds the Ultimate Ears outer shell of the Wonderboom 3 speaker. The hard outer layer and mesh covering around the speaker allows it to be used outdoors as it protects it from water and dirt.
Before using this guide, examine the mesh for rips and tears. If the mesh on your speaker is damaged, follow this guide to replace it with a new mesh. Make sure the speaker is powered off, but no charge is necessary for this replacement.
你所需要的
To unclip the top of the speaker from the body, insert the metal spudger to the left of the speaker's center. To find the correct position, make sure the pointed end of the spudger is inserted entirely.
While in this position, press down and into the speaker to unclip the top. You should feel and hear and audible click.
Repeat this on all four sides of the speaker. The speaker's top will snap off when you press down on it, so make sure you hold onto the top so it does not fly off.
2等其他人完成本指南。
