跳转到主内容
加入维修社区 - 创建账户
Ulco Integrus PSV Battery Replacement
医疗设备
iFixit 或本维修指南均未获得医疗设备制造商的认可或与任何制造商存在附属关系。
你所需要的
    • Before disassembly, make sure the front wheel breaks are on.
    • Make sure ALL gas supplies are disconnected and the system has been purged, and make sure all electrical supplies have been disconnected.
  1. Ulco Integrus PSV Battery Replacement: 步骤 4 中的图像 1,1
    • With one hand on the ventilator removal handle and one holding the lower half of the ventilator, pull up firmly on the handle so that the mounting slides up the slots in the frame.
  2. Ulco Integrus PSV Battery Replacement: 步骤 5 中的图像 1,1
    • Pull the ventilator housing towards you so that the mounting tabs come out of the frame slots rest the ventilator housing on the plastic skirt at the rear of the workstation as shown in the photo.
  3. Ulco Integrus PSV Battery Replacement, Removing the Rear Access Panels in the Ulco Integrus PSV: 步骤 6 中的图像 1,1
    • Remove the rear plastic cover by turning the single hex key retaining clip to free the cover.
  4. Ulco Integrus PSV Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the four screws mounted to the cover plate using a 4mm Allen key.
  5. Ulco Integrus PSV Battery Replacement, Battery: 步骤 8 中的图像 1,1
    • Remove the main cover plate from the ventilator enclosure by removing all screws.
    • Disconnect the battery.
  6. Ulco Integrus PSV Battery Replacement: 步骤 10 中的图像 1,1
    • Remove the four pan head screws (SM0308P) holding down the battery plate (EV9109) and battery (EV9108) and remove the battery plate and battery.
  7. Ulco Integrus PSV Battery Replacement: 步骤 11 中的图像 1,1
    • Install the new battery in the same location and screw down the battery plate onto the battery plate spacers so that the battery is firmly held in place.
    • Reconnect the battery.
结论
Preston Myers
于04/09/20注册
493 声望
创作了4篇指南
团队
Cal Poly, Team S7-G13, Paton Spring 2020 Cal Poly, Team S7-G13, Paton Spring 2020 的会员
CPSU-PATON-S20S7G13
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 129
