跳转到主内容
加入维修社区 - 创建账户
Ukulele String Replacement
你所需要的
    1. Ukulele String Replacement, Ukulele String Replacement: 步骤 1 中的图像 1,1
      • Prepare by gathering all of the things you'll need: your ukulele, the new string, a pair or scissors, a sharpened pencil, a cloth, a string winder (optional), and a tuner or tuning app. Make sure you purchase the right sized strings.
      • Remove the old string by untying it from the bridge.
      • Unwind the string with its tuning peg.
      询问修复机器人
      添加评论
    2. Ukulele String Replacement: 步骤 2 中的图像 1,1
      • Clean the ukulele with a paper towel or cloth. Make sure to clean around the bridge and the tuners.
      询问修复机器人
      添加评论
    3. Ukulele String Replacement: 步骤 3 中的图像 1,1
      • The next step is to smooth run the strings. Use a sharpened pencil to add a little graphite to the indent where the string will lie. This helps the string slide smoothly through the slot.
      询问修复机器人
      添加评论
    4. Ukulele String Replacement: 步骤 4 中的图像 1,3 Ukulele String Replacement: 步骤 4 中的图像 2,3 Ukulele String Replacement: 步骤 4 中的图像 3,3
      • Tie-up the string to the bride of the Ukulele. Begin by sliding one end of the string through the holes on the bridge. Then wrap it around itself, as shown in the image. Make sure that it is snug against the bridge.
      • With the excess string, wrap it under the string once, and then twice. This will prevent the string from slipping.
      • Finally, to make it anchored, pull the string tightly into place.
      询问修复机器人
      添加评论
    5. Ukulele String Replacement: 步骤 5 中的图像 1,3 Ukulele String Replacement: 步骤 5 中的图像 2,3 Ukulele String Replacement: 步骤 5 中的图像 3,3
      • Put the end of the string through the hole in the tuning peg, and tightly wrap the string around the peg three times.
      • If it is wrapped more than three times, it may interfere with tuning, and less than three times could make it less secure.
      • Next, turn the tuning peg until there is tension in the string. This process can be sped up by using a string winder. Then snip off the excess string with a scissors.
      询问修复机器人
      添加评论
    6. Ukulele String Replacement: 步骤 6 中的图像 1,1
      • The final step is to tune your ukulele. Although this can be done by ear, you may find it easier to use a tuner or a tuning app.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Bekah Klemp
于09/19/18注册
154 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 24
总计 1,671
