跳转到主内容
Udi Discovery U818A FPV Camera Replacement
你所需要的
  1. Udi Discovery U818A FPV Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Place the drone on its back, with the runners facing upward.
    • Using the Phillips #00 screwdriver, unscrew the single 2mm screw located on the drone body which connects the headlamp and wiring to the center of the drone frame.
  2. Udi Discovery U818A FPV Camera Replacement: 步骤 2 中的图像 1,1
    • Grasp one of the propeller arms with the fingers of one hand while holding the drone frame with the other hand.
    • Firmly pull the propeller arm upward to separate it from the drone body.
    • Repeat this process to remove the three other propeller arms.
  3. Udi Discovery U818A FPV Camera Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the drone body from the frame.
  4. Udi Discovery U818A FPV Camera Replacement: 步骤 4 中的图像 1,2 Udi Discovery U818A FPV Camera Replacement: 步骤 4 中的图像 2,2
    • Flip the drone body onto the runners so the wires and motherboard are facing upward.
    • Disconnect the black and blue camera wires from the motherboard.
    • You may need to use a pointed metal pick to loosen the red putty that holds the connectors together.
  5. Udi Discovery U818A FPV Camera Replacement: 步骤 5 中的图像 1,1
    • Be careful when separating the camera away from the runners and drone body—the plastic is brittle and may snap, causing injury to the hand.
    • Pry the camera away from the main drone body.
    • Use a spudger for extra leverage if the parts do not easily separate.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 265
