跳转到主内容
UTILITECH #HVT-8H Motor Replacement
你所需要的
  1. UTILITECH #HVT-8H Motor Replacement, Motor: 步骤 1 中的图像 1,1
    • Use a spudger to remove the screw covers.
    • Pry gently to avoid breaking the clips.
  2. UTILITECH #HVT-8H Motor Replacement: 步骤 2 中的图像 1,3 UTILITECH #HVT-8H Motor Replacement: 步骤 2 中的图像 2,3 UTILITECH #HVT-8H Motor Replacement: 步骤 2 中的图像 3,3
    • Use your Phillips #0 screwdriver to remove the 8 mm screw that attaches the fan to its stand.
    • Repeat step 1 and 2 on the other side of the fan.
  3. UTILITECH #HVT-8H Motor Replacement: 步骤 3 中的图像 1,2 UTILITECH #HVT-8H Motor Replacement: 步骤 3 中的图像 2,2
    • Use a spudger to remove the silver screw cover from the front of the fan.
    • Do not try to force the piece off as it could break. Instead, gently pry around the entire fan until it pops loose.
  4. UTILITECH #HVT-8H Motor Replacement: 步骤 4 中的图像 1,2 UTILITECH #HVT-8H Motor Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the four 6 mm screws that hold the fan cover in place.
  5. UTILITECH #HVT-8H Motor Replacement: 步骤 5 中的图像 1,3 UTILITECH #HVT-8H Motor Replacement: 步骤 5 中的图像 2,3 UTILITECH #HVT-8H Motor Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #0 screwdriver to remove the two 8 mm screws that attach the motor assembly to the base of the fan.
  6. UTILITECH #HVT-8H Motor Replacement: 步骤 6 中的图像 1,3 UTILITECH #HVT-8H Motor Replacement: 步骤 6 中的图像 2,3 UTILITECH #HVT-8H Motor Replacement: 步骤 6 中的图像 3,3
    • Remove the power control knob by pulling on the knob backward.
    • Use a 10 mm socket wrench to remove the 10 mm nut that holds the power control piece in place.
  7. UTILITECH #HVT-8H Motor Replacement: 步骤 7 中的图像 1,2 UTILITECH #HVT-8H Motor Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the two 8 mm screws that fasten the power plug to the base.
  8. UTILITECH #HVT-8H Motor Replacement: 步骤 8 中的图像 1,3 UTILITECH #HVT-8H Motor Replacement: 步骤 8 中的图像 2,3 UTILITECH #HVT-8H Motor Replacement: 步骤 8 中的图像 3,3
    • Cut the two black cables to release them from the motor assembly.
    • Be sure to cut as closely as you can to the base of the cables so you don't lose a lot of length.
  9. UTILITECH #HVT-8H Motor Replacement: 步骤 9 中的图像 1,2 UTILITECH #HVT-8H Motor Replacement: 步骤 9 中的图像 2,2
    • Use a wire stripper on the black wires to expose the metal underneath the rubber.
    • Strip about 13 mm from the end of both wires.
  10. UTILITECH #HVT-8H Motor Replacement: 步骤 10 中的图像 1,2 UTILITECH #HVT-8H Motor Replacement: 步骤 10 中的图像 2,2
    • Connect the exposed power plug wires to the new motor assembly by twisting the two exposed wires together.
    • Wrap electrical tape around the newly connected wires.
结论
Joseph Pemberton
于02/26/24注册
181 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 38
总计 914
