简介
If you are unsure how to write an ISO to a USB flash drive, this guide will show you how using Rufus. Many modern systems do not include an internal optical drive and require a USB flash drive to boot unless you use a USB optical drive. This is especially common on modern laptops as well as some desktops where it is an option and is not standard. In many cases, using a USB drive is a more practical workaround with these systems.
Unless your application REQUIRES a DVD, it is generally better to use a USB flash drive that is at least 16GB*.
*An 8GB drive can often be used as well. However, due to the cost difference in manufacturing and retail, these drives tend to only be sold in bulk, unless it is a no-name drive purchased online. Do not waste your time and money on a new 8GB USB drive with how cheap 16GB drives have gotten.
READ: Important note about legacy operating systems.
Important: OSes without USB boot support are not guaranteed to work. While the risk of a problem is low, results outside of Linux and modern Windows/MacOS releases are NOT GUARANTEED.
This guide was originally written just for Linux. However, it can be used with any operating system that supports USB boot and is not tied to one specific operating system in practice. Since these operating systems can create unforeseen issues, you are on your own.
Guide notes
- If you have a used USB drive, format it outside of Rufus before use.
- DVD creation is not covered. It was covered in Revision 1 but got lost with time.
- This guide is on Revision 3. If you are using Rufus 2.x, refer to Revision 2.
你所需要的
After downloading Rufus, download the ISO you want to write to the USB drive.
Open Rufus and click SELECT. Find the ISO and click Open.
Rufus will ask you to choose ISO or DD mode. If unsure, choose ISO mode.
After configuring the writing process, click start. Click OK on the formatting warning.
10等其他人完成本指南。
2条评论
Unetbootin does not work anymore and is considered unstable to use when installing any Linux OS, also 4GB USB drives are more than big enough to get the job done
My reasoning for saying 8GB is because 4GB sticks are all but nonexistent (8GB is more popular now), but if you already own the 4GB stick then it'll work. I even use one from 2006 in the guide, to show that reuse is possible.
Oh really? I always thought it was still a usable option - thanks for letting me know that I was wrong.
Nick -
