跳转到主内容
UP! Plus 2 Spool Holder Replacement
你所需要的
  1. UP! Plus 2 Spool Holder Replacement, 3D print replacement spool holder: 步骤 1 中的图像 1,1
    • Before your spool holder breaks, 3D print a replacement to have on hand. If you didn't preemptively print a replacement you can still print without a spool holder. Just find some way of holding the spool so that it can rotate as the filament gets pulled off.
    • Download the file for a new spool holder here
  2. UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 步骤 2 中的图像 1,3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 步骤 2 中的图像 2,3 UP! Plus 2 Spool Holder Replacement, Remove plastic filaments: 步骤 2 中的图像 3,3
    • Go to "Maintenance" and tell the printer to withdraw the plastic filament from the extrusion assembly. Finish removing the filament by pulling upwards.
    • Wait for a "beeping" sound before removing filament.
    • Cut off any damaged plastic from the end of the filament.
    • Remove the plastic filament tube from the spool.
  3. UP! Plus 2 Spool Holder Replacement, Remove spool holder: 步骤 3 中的图像 1,3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: 步骤 3 中的图像 2,3 UP! Plus 2 Spool Holder Replacement, Remove spool holder: 步骤 3 中的图像 3,3
    • Remove the spool from the spool holder by lifting it up and taking it off.
    • Put the end of the filament through the hole on the side of the spool to keep it from unraveling.
    • Slide the spool holder upwards, and then pull outwards.
  4. UP! Plus 2 Spool Holder Replacement, Replace spool holder: 步骤 4 中的图像 1,3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: 步骤 4 中的图像 2,3 UP! Plus 2 Spool Holder Replacement, Replace spool holder: 步骤 4 中的图像 3,3
    • Place the new spool holder by pushing it inwards and sliding it down until it locks.
    • Repeat the steps in reverse chronological order to reassemble the printer.
    • The spool should be inserted in way that end of the filament points towards, not away.
终点
6等其他人完成本指南。
valerie boyer
于10/12/14注册
508 声望
创作了4篇指南
团队
Cal Poly, Team 14-31, Maness Fall 2014 Cal Poly, Team 14-31, Maness Fall 2014 的会员
CPSU-MANESS-F14S14G31
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,204
