跳转到主内容
UE BOOM 2 Speaker Replacement
你所需要的
  1. UE BOOM 2 Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 UE BOOM 2 Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 UE BOOM 2 Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Remove the D-ring located at the bottom of the device, opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
    • Removing the D-ring will allow you to be able to remove the rubber port cover revealing the headphone jack and charging port.
  2. UE BOOM 2 Speaker Replacement: 步骤 2 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 2 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  3. UE BOOM 2 Speaker Replacement: 步骤 3 中的图像 1,1
    • Continue removing the rubber stripping down the side.
  4. UE BOOM 2 Speaker Replacement: 步骤 4 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 4 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 4 中的图像 3,3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips Head #2 screwdriver.
    • Pry up at the location marked, and remove the plastic end cap.
    • Repeat these steps on the top of the speaker.
  5. UE BOOM 2 Speaker Replacement: 步骤 5 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 5 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 5 中的图像 3,3
    • Carefully un-loop the cable and unplug from motherboard.
    • Pull out the battery, and handle with care.
  6. UE BOOM 2 Speaker Replacement: 步骤 6 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 6 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 6 中的图像 3,3
    • Using the metal spudger, pry up the plastic tab on the inside.
    • Pry up around the entire inside circumference.
    • Repeat on the other end.
  7. UE BOOM 2 Speaker Replacement: 步骤 7 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 7 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 7 中的图像 3,3
    • Using the metal spudger tool, pry up the inside edge of the mesh lining.
    • Working down the strip on both sides. Careful as to not rip the mesh.
  8. UE BOOM 2 Speaker Replacement: 步骤 8 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 8 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 8 中的图像 3,3
    • Unscrew the two 5mm Phillips Head #1 screws, using a Phillips Head #1 screwdriver.
    • Using the metal spudger, pry open the edge of the cover.
  9. UE BOOM 2 Speaker Replacement: 步骤 9 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 9 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 9 中的图像 3,3
    • Using the metal spudger, pry the plastic casing up.
    • Repeat on the other side of the speaker.
  10. UE BOOM 2 Speaker Replacement: 步骤 10 中的图像 1,2 UE BOOM 2 Speaker Replacement: 步骤 10 中的图像 2,2
    • Pull each cover off.
  11. UE BOOM 2 Speaker Replacement: 步骤 11 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 11 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 11 中的图像 3,3
    • Using the metal spudger, specifically the pointy end, find the gap between the speaker and billow (the large speaker-like object next to the speaker).
    • Pry the metal wire up and out at exactly this gap, then slide down wire towards one end to pop it out completely.
    • Once one end is out, use fingers to gently pull off completely, so as not to bend the wire to aggressively.
  12. UE BOOM 2 Speaker Replacement: 步骤 12 中的图像 1,1
    • Repeat previous process for other side of the speaker and billow.
  13. UE BOOM 2 Speaker Replacement: 步骤 13 中的图像 1,2 UE BOOM 2 Speaker Replacement: 步骤 13 中的图像 2,2
    • Using the metal spudger, work it under the billow (circled).
    • Work the billow up around all edges, and pull out of casing.
  14. UE BOOM 2 Speaker Replacement: 步骤 14 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 14 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 14 中的图像 3,3
    • With the billow removed, pry up the pink rubber seal with the metal spudger, and remove.
    • Do not use excessive force with the metal spudger, doing so may damage the seal.
  15. UE BOOM 2 Speaker Replacement: 步骤 15 中的图像 1,3 UE BOOM 2 Speaker Replacement: 步骤 15 中的图像 2,3 UE BOOM 2 Speaker Replacement: 步骤 15 中的图像 3,3
    • Now, begin to use the same technique for the speaker.
    • Be sure to remove the speaker slowly, as there is a cable attaching the speaker to the motherboard.
  16. UE BOOM 2 Speaker Replacement: 步骤 16 中的图像 1,2 UE BOOM 2 Speaker Replacement: 步骤 16 中的图像 2,2
    • Once speaker is detached from casing, remove cable from motherboard.
    • Connect new speaker by attaching the cable to the same place where the old speaker was just taken out of.
    • If both speakers are blown out, repeat steps 14-16 on the other side.
结论
14等其他人完成本指南。
Keegan Divine
于01/18/18注册
649 声望
撰写一个指南
团队
Cal Poly, Team S12-G5, Banghart Winter 2018 Cal Poly, Team S12-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G5
2 名成员
创作了15篇指南
10指南评论
Hi, very good tutorial, you got your 30 points ! ;)
But the main question remains to me : where to get a new speaker as UE doen’t sell spare parts and I don’t find any replacement on internet … any help more than welcome …
Cheers!
Francois ORSERO - 回复
did you managed to source a replacement speaker? im having the same problem
marleybetteridge -
Still did not find replacement … what about you guys ?
Francois ORSERO -
Check my update you may not have to buy a replacement
Kyle White -
Check with a multimeter if the speakers are actually faulty. Mine were fine, turns out another component broke off and so I soldered it back on. Now it works fine.
Stig -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 34
过去 30 天: 129
总计 17,473
