跳转到主内容
UE BOOM 2 Micro-USB Port Replacement
你所需要的
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: 步骤 1 中的图像 1,2 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: 步骤 1 中的图像 2,2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: 步骤 2 中的图像 1,2 UE BOOM 2 Micro-USB Port Replacement: 步骤 2 中的图像 2,2
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: 步骤 3 中的图像 1,3 UE BOOM 2 Micro-USB Port Replacement: 步骤 3 中的图像 2,3 UE BOOM 2 Micro-USB Port Replacement: 步骤 3 中的图像 3,3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  4. UE BOOM 2 Micro-USB Port Replacement: 步骤 4 中的图像 1,1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: 步骤 5 中的图像 1,3 UE BOOM 2 Micro-USB Port Replacement: 步骤 5 中的图像 2,3 UE BOOM 2 Micro-USB Port Replacement: 步骤 5 中的图像 3,3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
结论
8等其他人完成本指南。
Alex Bahm
于01/18/18注册
2,325 声望
创作了6篇指南
团队
Cal Poly, Team S12-G5, Banghart Winter 2018 Cal Poly, Team S12-G5, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G5
2 名成员
创作了15篇指南
6指南评论
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - 回复
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - 回复
i too am looking to find the replacement part
Liam Nicholls - 回复
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - 回复
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 116
总计 10,754
