跳转到主内容
UDI U818A Drone Cover Replacement
你所需要的
  1. UDI U818A Drone Cover Replacement, Propellers: 步骤 1 中的图像 1,2 UDI U818A Drone Cover Replacement, Propellers: 步骤 1 中的图像 2,2
    • Remove the 5 mm screws connecting each propeller to the rotating post using a Phillips #000 screwdriver.
    • As each screw is removed, safely pull the respective propeller from its apparatus.
  2. UDI U818A Drone Cover Replacement, Drone Cover: 步骤 2 中的图像 1,2 UDI U818A Drone Cover Replacement, Drone Cover: 步骤 2 中的图像 2,2
    • Remove four 3 mm screws connecting the electronics to the frame using a Phillips #000 screwdriver.
    • Pull the two LED bars through the dust cover and remove the thin plastic dust cover from the drone.
    • As the piece connecting the electronics to the drone cover are accessible, keep note to not remove electronics until after disconnecting the drone head lamp first.
  3. UDI U818A Drone Cover Replacement: 步骤 3 中的图像 1,2 UDI U818A Drone Cover Replacement: 步骤 3 中的图像 2,2
    • Remove the single 5 mm screw from the head lamp using a Phillips #000 screwdriver.
    • Remove the head lamp from the rest of the drone.
    • Disconnect the electronics from the frame of the drone by pulling each arm out of the hole in the frame holding it in place.
    • Do not try to separate the frame from the electronics yet! Check to see if there is tape holding the head lamp wires in place underneath the electronics.
  4. UDI U818A Drone Cover Replacement: 步骤 4 中的图像 1,3 UDI U818A Drone Cover Replacement: 步骤 4 中的图像 2,3 UDI U818A Drone Cover Replacement: 步骤 4 中的图像 3,3
    • If present, remove the white tape over the black and red wires on the head lamp with a spudger.
    • Keep the tape in reusable condition to re-secure the headlight later so there are no loose wires.
    • Separate the plastic tabs securing the motor arms to the drone cover and delicately pull out the arm. Do this for all four arms to remove the frame from the cover.
结论
3等其他人完成本指南。
团队
UMass Dartmouth, Team 1-4, Miles Spring 2016 UMass Dartmouth, Team 1-4, Miles Spring 2016 的会员
UMASSD-MILES-S16S1G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,311
