跳转到主内容
加入维修社区 - 创建账户
Two-Hole Button Replacement
你所需要的
  1. Two-Hole Button Replacement, Two-Hole Button: 步骤 1 中的图像 1,1
    • Choose a thread that will match the rest of the buttons on the jacket/button.
  2. Two-Hole Button Replacement: 步骤 2 中的图像 1,1
    • Thread the needle so that there is equal thread on both sides of the needle.
  3. Two-Hole Button Replacement: 步骤 3 中的图像 1,2 Two-Hole Button Replacement: 步骤 3 中的图像 2,2
    • Tie a knot at the end of the thread so that it will not come back through the buttonhole.
  4. Two-Hole Button Replacement: 步骤 4 中的图像 1,1
    • Place the button on the fabric that you are sewing it back on to.
  5. Two-Hole Button Replacement: 步骤 5 中的图像 1,2 Two-Hole Button Replacement: 步骤 5 中的图像 2,2
    • Take the threaded needle and push it through the fabric and one of the buttonholes on the bottom side and pull it through.
  6. Two-Hole Button Replacement: 步骤 6 中的图像 1,2 Two-Hole Button Replacement: 步骤 6 中的图像 2,2
    • Thread the needle down through the second hole of the button.
  7. Two-Hole Button Replacement: 步骤 7 中的图像 1,1
    • Place a straight pin on the backside of the button to keep the button from being sewn on too tight.
  8. Two-Hole Button Replacement: 步骤 8 中的图像 1,2 Two-Hole Button Replacement: 步骤 8 中的图像 2,2
    • Repeat steps 5-6 to continue sewing the button on until secure.
  9. Two-Hole Button Replacement: 步骤 9 中的图像 1,2 Two-Hole Button Replacement: 步骤 9 中的图像 2,2
    • Once the button is secure, push the needle through the fabric but not the button and remove the pin.
  10. Two-Hole Button Replacement: 步骤 10 中的图像 1,2 Two-Hole Button Replacement: 步骤 10 中的图像 2,2
    • Once the pin is removed, wrap the thread around the button 6-7 times and push the needle through the fabric on the underside of the button.
  11. Two-Hole Button Replacement: 步骤 11 中的图像 1,3 Two-Hole Button Replacement: 步骤 11 中的图像 2,3 Two-Hole Button Replacement: 步骤 11 中的图像 3,3
    • To finish sewing, make 3-4 stitches to tie off.
  12. Two-Hole Button Replacement: 步骤 12 中的图像 1,3 Two-Hole Button Replacement: 步骤 12 中的图像 2,3 Two-Hole Button Replacement: 步骤 12 中的图像 3,3
    • Cut the remaining thread off.
结论
Test out your fix by closing the jacket/clothing item with your resewn button!
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 24
总计 421
