跳转到主内容
Turtle Beach Recon Controller Front Buttons Replacement
你所需要的
  1. Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: 步骤 1 中的图像 1,3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: 步骤 1 中的图像 2,3 Turtle Beach Recon Controller Front Buttons Replacement, Back Plate: 步骤 1 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove seven 10 mm screws from the back plate.
    • When replacing the screws, ensure that the screwdriver is perpendicular to the screw in curved areas.
  2. Turtle Beach Recon Controller Front Buttons Replacement: 步骤 2 中的图像 1,3 Turtle Beach Recon Controller Front Buttons Replacement: 步骤 2 中的图像 2,3 Turtle Beach Recon Controller Front Buttons Replacement: 步骤 2 中的图像 3,3
    • Use an opening tool to separate the back plate from the grips of your Turtle Beach Recon.
    • Use your fingers to remove the back plate from the body of your Turtle Beach Recon.
  3. Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: 步骤 3 中的图像 1,2 Turtle Beach Recon Controller Front Buttons Replacement, Face Plate: 步骤 3 中的图像 2,2
    • Remove the four 10 mm screws from the motherboard using a Phillips #00 screwdriver.
  4. Turtle Beach Recon Controller Front Buttons Replacement: 步骤 4 中的图像 1,2 Turtle Beach Recon Controller Front Buttons Replacement: 步骤 4 中的图像 2,2
    • Use your fingers to grab the motherboard.
    • Gently pull the motherboard and joystick caps away from the face plate.
  5. Turtle Beach Recon Controller Front Buttons Replacement: 步骤 5 中的图像 1,3 Turtle Beach Recon Controller Front Buttons Replacement: 步骤 5 中的图像 2,3 Turtle Beach Recon Controller Front Buttons Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove six 10 mm screws from the motherboard.
  6. Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: 步骤 6 中的图像 1,3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: 步骤 6 中的图像 2,3 Turtle Beach Recon Controller Front Buttons Replacement, Front Buttons: 步骤 6 中的图像 3,3
    • Gently remove front buttons from the face plate by hand.
结论
另外一个人完成了本指南。
Mary Goodrow
于03/22/24注册
671 声望
创作了5篇指南
团队
UMass Dartmouth, Team 6-1, Botvin Spring 2024 UMass Dartmouth, Team 6-1, Botvin Spring 2024 的会员
UMASSD-BOTVIN-S24S6G1
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 34
总计 441
