跳转到主内容
Turtle Beach Recon 70P Speakers Replacement
你所需要的
  1. Turtle Beach Recon 70P Speakers Replacement, Speaker: 步骤 1 中的图像 1,3 Turtle Beach Recon 70P Speakers Replacement, Speaker: 步骤 1 中的图像 2,3 Turtle Beach Recon 70P Speakers Replacement, Speaker: 步骤 1 中的图像 3,3
    • Before continuing, remove the ear pad(s) from the nonfunctional speaker(s) following the earpad replacement guide.
    • Use a spudger to pry up and remove the black plastic cover.
  2. Turtle Beach Recon 70P Speakers Replacement: 步骤 2 中的图像 1,2 Turtle Beach Recon 70P Speakers Replacement: 步骤 2 中的图像 2,2
    • Use flush cutters to cut the wires as close to the speaker connections as possible.
  3. Turtle Beach Recon 70P Speakers Replacement: 步骤 3 中的图像 1,3 Turtle Beach Recon 70P Speakers Replacement: 步骤 3 中的图像 2,3 Turtle Beach Recon 70P Speakers Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to pry the speaker out of its housing.
    • The speaker is attached to the housing with adhesive, so moderate force may be necessary to pry it out of place..
  4. Turtle Beach Recon 70P Speakers Replacement: 步骤 4 中的图像 1,2 Turtle Beach Recon 70P Speakers Replacement: 步骤 4 中的图像 2,2
    • Insert the new speaker into the plastic housing, sealing it in place with glue or tape.
    • Solder the wires in the order they were previously found.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 68
