跳转到主内容
Turtle Beach REACT-R Motherboard Replacement
你所需要的
  1. Turtle Beach REACT-R Motherboard Replacement, Rear Case: 步骤 1 中的图像 1,3 Turtle Beach REACT-R Motherboard Replacement, Rear Case: 步骤 1 中的图像 2,3 Turtle Beach REACT-R Motherboard Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
  2. Turtle Beach REACT-R Motherboard Replacement, Motherboard: 步骤 2 中的图像 1,3 Turtle Beach REACT-R Motherboard Replacement, Motherboard: 步骤 2 中的图像 2,3 Turtle Beach REACT-R Motherboard Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
结论
Dodi Imam
于02/16/24注册
637 声望
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 26
总计 392
