跳转到主内容
加入维修社区 - 创建账户
Turtle Beach REACT-R Joystick Covers Replacement
你所需要的
  1. Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: 步骤 1 中的图像 1,3 Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: 步骤 1 中的图像 2,3 Turtle Beach REACT-R Joystick Covers Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Place the controller face down.
    • Use a Phillips #00 screwdriver to remove the seven 9.2 mm Phillips screws that secure the rear case.
    • Use both hands to lift the backplate away from the controller.
  2. Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: 步骤 2 中的图像 1,3 Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: 步骤 2 中的图像 2,3 Turtle Beach REACT-R Joystick Covers Replacement, Motherboard: 步骤 2 中的图像 3,3
    • Use a Phillips #00 to remove the four 9.2 mm screws that secure the motherboard.
    • Two of the screws are hidden under the red and black vibration motor wires.
    • Gently lift the motherboard up and out of the chassis.
    • Be careful not to strain the vibration motor wires.
  3. Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: 步骤 3 中的图像 1,3 Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: 步骤 3 中的图像 2,3 Turtle Beach REACT-R Joystick Covers Replacement, Joystick Covers: 步骤 3 中的图像 3,3
    • Gently twist off each thumb stick, using one hand to secure the base, and the other to twist off the thumb stick.
结论
2等其他人完成本指南。
Dodi Imam
于02/16/24注册
637 声望
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 56
总计 869
