跳转到主内容
Turtle Beach PX22 Microphone Replacement
你所需要的
  1. Turtle Beach PX22 Microphone Replacement, Microphone: 步骤 1 中的图像 1,3 Turtle Beach PX22 Microphone Replacement, Microphone: 步骤 1 中的图像 2,3 Turtle Beach PX22 Microphone Replacement, Microphone: 步骤 1 中的图像 3,3
    • Use your fingers to peel off ear cushion by pinching and pulling off the leather.
    • Use the Philips #00 head screwdriver to remove three screws around the speaker (9/32 in length, 1/8 inch head)
    • The housing will comes loose. Take note of position of the wires.
  2. Turtle Beach PX22 Microphone Replacement: 步骤 2 中的图像 1,1
    • Remove the 9/32 inch screw with a Philips 2 screwdriver to gain access to microphone.
    • You may need to pull the wire with the knot out of the way of the screw.
  3. Turtle Beach PX22 Microphone Replacement: 步骤 3 中的图像 1,1
    • Apply heat to the circled wires on the circuit board with a heat gun.
    • Insert the new microphone and solder the wires into the correct positions.
    • Pull the excess microphone wire back into the speaker housing.
    • Use the Philips #2 screwdriver to replace the screw and fix the microphone.
    • Hold the microphone neck so that it does no rotate when screwing.
  4. Turtle Beach PX22 Microphone Replacement: 步骤 4 中的图像 1,3 Turtle Beach PX22 Microphone Replacement: 步骤 4 中的图像 2,3 Turtle Beach PX22 Microphone Replacement: 步骤 4 中的图像 3,3
    • Position the speaker on the headset so that the screw holes line up. It should click into place.
    • Screw in the 3 screws with the 00 Philips head screwdriver.
    • Place the new cushion against speaker and wrap the leather around the plastic. Do this by working around the cushion to get all of the leather around the plastic.
    • Use the plastic opening tool to tuck excess leather inside the headset.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 3-1, Duarte Spring 2015 UMass Dartmouth, Team 3-1, Duarte Spring 2015 的会员
UMASSD-DUARTE-S15S3G1
4 名成员
创作了8篇指南
3条评论
Where do we buy the mic?
Brit B - 回复
could someone help me say what each and every on of those wire points on this logic board goes to? like 1,2,3,4,5 and 6, what do they go to???
alexalv55 - 回复
i need the cable for my px 24 it broke in my phone how do i get a new cable to fix my px 24 headset
rjbubba1960 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 6,735
