当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Begin by flipping over the transmitter, and removing the padding from the underside of it. This will reveal the screws to take apart the device.
Remove the screws ( 11.27mm Phillips head) and open up the transmitter to reveal the internal components. Carefully pry open the transmitter, and use caution when opening it up as to not sever the wire.
Remove the two screws (5.21mm Phillips head) on the board on the top half of the transmitter that is holding the charging pins.
Once the screws are removed, desolder the two wires from the board, and then remove it, and the charging pins with it.
Take extreme caution when dealing with a soldering iron. Refer to the desoldering guide for tips.
Note that for the purposes of this guide we simply clipped the wires connected to the board holding the charging pins.
取消:我没有完成这个指南。
与2其他贡献者
于01/18/17注册
861 声望
创作了5篇指南
徽章: 12
+ 9更多徽章
ARSU-CHAMBERLAIN-S17S1G5
3 名成员
创作了10篇指南
Where did you get the new contact pins?
Kenneth Roberts - 2018年1月28日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 8
总计 1,546
