跳转到主内容
Turtle Beach Elite 800 Charging Pins on Headset Replacement
你所需要的
  1. Turtle Beach Elite 800 Charging Pins on Headset Replacement, Ear Cushion: 步骤 1 中的图像 1,2 Turtle Beach Elite 800 Charging Pins on Headset Replacement, Ear Cushion: 步骤 1 中的图像 2,2
    • To remove the ear cushions, press firmly down and rotate them clockwise, it should twist about 2mm and release, allowing you to pull it off.
    • When reassembling, be sure to line up the locking plates.
  2. Turtle Beach Elite 800 Charging Pins on Headset Replacement, Charging Contact Pins on Headset: 步骤 2 中的图像 1,2 Turtle Beach Elite 800 Charging Pins on Headset Replacement, Charging Contact Pins on Headset: 步骤 2 中的图像 2,2
    • Use the Phillips #0 screw bit to remove the four screws (9.47 mm long) that have been revealed from removing the ear cup. Carefully take off the blue casing to reveal the audio board.
  3. Turtle Beach Elite 800 Charging Pins on Headset Replacement: 步骤 3 中的图像 1,3 Turtle Beach Elite 800 Charging Pins on Headset Replacement: 步骤 3 中的图像 2,3 Turtle Beach Elite 800 Charging Pins on Headset Replacement: 步骤 3 中的图像 3,3
    • Use the Phillips #00 screw bit to remove the two screws (7.92 mm long) that are holding the contact pins in place.
    • Then, simply push the pins from the board.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 933
