跳转到主内容
Turtle Beach Ear Force XO Seven Slide Adjustment Replacement
你所需要的
  1. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: 步骤 1 中的图像 1,2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Take out the screws: 步骤 1 中的图像 2,2
    • Remove the two 1.0 cmTorx T6 screws using the matching Torx T6 screwdriver.
  2. Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: 步骤 2 中的图像 1,2 Turtle Beach Ear Force XO Seven Slide Adjustment Replacement, Pop off the plastic mechanism: 步骤 2 中的图像 2,2
    • Insert the spudger into the gap between the leather and plastic.
    • After making sure you have a good grip, use the spudger to pry the two plastic pieces apart.
结论
4等其他人完成本指南。
Nancy Truong
于01/30/15注册
375 声望
创作了2篇指南
团队
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G36
4 名成员
创作了12篇指南
7条评论
What if the plastic part that connects the earphones to the headband breaks and is there a way I can fix or replace that ??
jamesfalduto - 回复
I really don't want to buy another turtle beach headset
jamesfalduto - 回复
James did you ever find a solution because I have the same problem
Commandcorps - 回复
Same problem here commandcorps.
adampm1 -
Same problem… plastic slide adjustment broke… contacted turtle beach and haven’t heard back… it should be an easy fix but can’t find the parts anywhere thus far…
Jim Davis - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 4,298
