跳转到主内容
Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement
你所需要的
  1. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: 步骤 1 中的图像 1,2 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Unplug microphone from headset: 步骤 1 中的图像 2,2
    • The microphone is a separate piece. So, unplug it from the headset.
  2. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: 步骤 2 中的图像 1,2 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Removing the screw: 步骤 2 中的图像 2,2
    • Using a Philips #0 screwdriver, unscrew the 4-mm-long screw that attaches the windscreen to the microphone.
  3. Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: 步骤 3 中的图像 1,3 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: 步骤 3 中的图像 2,3 Turtle Beach Ear Force XO Seven Microphone Windscreen Replacement, Remove metal plate and then windscreen: 步骤 3 中的图像 3,3
    • Now that the screw is removed, remove the slim metal plate at the base of the windscreen by gently pulling on the plate.
    • Then slide the windscreen off of the microphone.
结论
Andrew Rudnick
于01/31/15注册
281 声望
创作了2篇指南
团队
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G36
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 14
总计 2,743
