跳转到主内容
Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement
你所需要的
  1. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement, Adapter Audio Jack Board: 步骤 1 中的图像 1,1
    • Wedge the Plastic Opening Tool below the plug and between the bottom plate and the body.
    • Leave the Plastic Opening Tool in place until the bottom piece is completely removed.
  2. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: 步骤 2 中的图像 1,3 Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: 步骤 2 中的图像 2,3 Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Be firm but controlled with the Spudger. Excessive force may cause tool marks or crack the plastic causing structural damage.
    • The clips on the inside of the bottom cover that attach to the bottom of the device may make removal difficult. Be patient and work slowly.
    • Wedge the Spudger at an upward angle in between the two pieces of plastic above the audio jack. Be careful, this may take a firm push.
    • Gently point the Spudger at a downward angle into the gap between the bottom cover and the rest of the device. Take care to work the Spudger all the way in between the pieces when doing so.
    • Use the Spudger as a lever to gently pop the bottom cover over the lip of the audio jack.
  3. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    T5 Torx Screwdriver
    $5.49
    购买
    • Unscrew the two T5 Torx head screws found on either side of the input for the controller. These screws are silver and 7.75mm in length.
    • Unscrew the three smaller black T5 Torx head screws. These screws are only 5mm in length and found around the perimeter of the input controller.
  4. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: 步骤 4 中的图像 1,3 Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: 步骤 4 中的图像 2,3 Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    Metal Spudger Set
    $7.99
    购买
    • Handle with care. The wires and the traces on the circuit board break easily.
    • Insert the sharp end of the Metal Spudger in between the male and the female ends of the nine pin connector and slowly work the ends apart.
  5. Turtle Beach Ear Force XO Seven Adapter Audio Jack Board Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    Phillips #0 Screwdriver
    $5.49
    购买
    • Remove the two Phillips #0 head screws on either side of the Audio Jack board. These screws are 5.5 mm in length.
    • Remove the Audio Jack Board.
结论
另外一个人完成了本指南。
Manuel Zavala
于01/31/15注册
117 声望
撰写一个指南
团队
Cal Poly, Team 17-36, Amido Winter 2015 Cal Poly, Team 17-36, Amido Winter 2015 的会员
CPSU-AMIDO-W15S17G36
4 名成员
创作了12篇指南
一条评论
Where do you get the replacement board??
Great write up, but no idea where to get the board.
Globe Spy - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 1,900
