跳转到主内容
Turtle Beach Ear Force XO One Adapter Buttons Replacement
你所需要的
  1. Turtle Beach Ear Force XO One Adapter Buttons Replacement, Adapter Buttons: 步骤 1 中的图像 1,1
    • Using a Philips head screwdriver, unscrew the two screws on the back of the adapter.
    • The recommended screwdriver bit size is a PH 000.
  2. Turtle Beach Ear Force XO One Adapter Buttons Replacement: 步骤 2 中的图像 1,1
    • Using your hands and/or a prying tool, carefully pry open the adapter.
    • This step may require a bit of force to complete.
    • Be aware that the adapter is held together with clips on the inside at some locations.
    • Do not be alarmed if it makes a snapping sound as it comes apart, this is most likely just the sound of the clips detaching.
  3. Turtle Beach Ear Force XO One Adapter Buttons Replacement: 步骤 3 中的图像 1,3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: 步骤 3 中的图像 2,3 Turtle Beach Ear Force XO One Adapter Buttons Replacement: 步骤 3 中的图像 3,3
    • Now, using the same Philips head screwdriver, unscrew the two screws on either side that hold the circuit board to the adapter case.
    • Once the screws are out, you can remove the circuit board from the casing.
  4. Turtle Beach Ear Force XO One Adapter Buttons Replacement: 步骤 4 中的图像 1,1
    • Push the rubber piece containing the buttons out of the plastic adapter casing.
    • Then, replace it with a new one.
结论
另外一个人完成了本指南。
Joseph Lane
于10/27/15注册
128 声望
撰写一个指南
团队
UMass Dartmouth, Team 3-1, Shastany Fall 2015 UMass Dartmouth, Team 3-1, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S3G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,561
