跳转到主内容
Turtle Beach Ear Force X12 Slide Adjustment Replacement
你所需要的
  1. Turtle Beach Ear Force X12 Slide Adjustment Replacement, Slide Adjustment: 步骤 1 中的图像 1,1
    • Remove the two 1.10 mm screws using the a T3 screwdriver.
  2. Turtle Beach Ear Force X12 Slide Adjustment Replacement: 步骤 2 中的图像 1,3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: 步骤 2 中的图像 2,3 Turtle Beach Ear Force X12 Slide Adjustment Replacement: 步骤 2 中的图像 3,3
    • Insert the plastic opening tool into the gap between the fabric and the plastic.
    • Make sure you have a firm grip, use the plastic opening tool to pry the two plastic pieces apart.
    • Be careful not to crack or brake the plastic pieces.
    • You should have two plastic pieces removed at the end. Replace them with new ones and reassemble.
结论
Katha Patel
于10/02/17注册
218 声望
创作了2篇指南
团队
USF Tampa, Team S1-G3, Thompson Fall 2017 USF Tampa, Team S1-G3, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S1G3
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 538
