跳转到主内容
Turtle Beach Ear Force Stealth 500P Speaker Replacement
你所需要的
  1. Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: 步骤 1 中的图像 1,3 Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: 步骤 1 中的图像 2,3 Turtle Beach Ear Force Stealth 500P Speaker Replacement, Earpad Assembly: 步骤 1 中的图像 3,3
    • Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
    • Work circularly until removed.
  2. Turtle Beach Ear Force Stealth 500P Speaker Replacement: 步骤 2 中的图像 1,2 Turtle Beach Ear Force Stealth 500P Speaker Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
    • Gently pull blue plastic from black housing by hand until separated.
  3. Turtle Beach Ear Force Stealth 500P Speaker Replacement, Speaker: 步骤 3 中的图像 1,1
    • Using metal prying tool, gently slide the tool between the speaker and the blue plastic holder to break up the adhesive.
  4. Turtle Beach Ear Force Stealth 500P Speaker Replacement: 步骤 4 中的图像 1,1
    • Depending on how much of the adhesive was able to be removed, you should be able to pry up the speaker assembly using plastic pry tool. If unsuccessful, use metal tool by gently working around speaker using small twisting motions until free.
  5. Turtle Beach Ear Force Stealth 500P Speaker Replacement: 步骤 5 中的图像 1,2 Turtle Beach Ear Force Stealth 500P Speaker Replacement: 步骤 5 中的图像 2,2
    • Using wire cutters, cut the red and black wires connecting the speaker to the circuit board. Be careful to leave at least one inch of wire to use reconnect wires to new speaker.
  6. Turtle Beach Ear Force Stealth 500P Speaker Replacement: 步骤 6 中的图像 1,1
    • Use wire strippers to strip a portion of the rubber colored coating on the wires about a quarter inch long from both the wires connected to the circuit board and the two red and blacks wires connected to the new speaker.
  7. Turtle Beach Ear Force Stealth 500P Speaker Replacement: 步骤 7 中的图像 1,1
    • Twist together the matching pairs of un-shielded copper wire (black on black and red on red) and cover with wire connectors to prevent shorting.
结论
另外一个人完成了本指南。
Noah Franklin
于10/27/15注册
445 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-3, Shastany Fall 2015 UMass Dartmouth, Team 2-3, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S2G3
3 名成员
创作了10篇指南
一条评论
This is the first guide I've found that covers how the speaker is mounted to the plate. Thanks!
Michael Merrell - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 18
总计 3,563
