跳转到主内容
Turtle Beach Ear Force Stealth 500P Battery Replacement
你所需要的
  1. Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 步骤 1 中的图像 1,3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 步骤 1 中的图像 2,3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Earpad Assembly: 步骤 1 中的图像 3,3
    • Remove the ear pad from the earphone by gently pulling the cloth pad outwards from the slot holding the cloth.
    • Work circularly until removed.
  2. Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 2 中的图像 1,2 Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 2 中的图像 2,2
    • Using a Phillips #1 screwdriver, remove the four fastening screws that hold the blue plastic speaker mount in place.
    • Gently pull blue plastic from black housing by hand until separated.
  3. Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 步骤 3 中的图像 1,3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 步骤 3 中的图像 2,3 Turtle Beach Ear Force Stealth 500P Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Use screwdriver tip J00 to remove three screws fastening circuit board to casing.
  4. Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 4 中的图像 1,2 Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use bent tweezers to remove two wire connector plugs from circuit board.
  5. Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 5 中的图像 1,2 Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 5 中的图像 2,2
    • Circuit board will be free to be removed by hand. Use plastic pry tool to slide between casing and circuit board if needed.
  6. Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 6 中的图像 1,1
    • Gently removed and flip over circuit board to reveal battery pack attached to the underside. Careful not to pull out wires running through headband.
  7. Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 7 中的图像 1,1
    • Use metal pry tool to slide between battery and circuit board to break up adhesive. Ensure the battery wire connector plug has been removed on front side.
  8. Turtle Beach Ear Force Stealth 500P Battery Replacement: 步骤 8 中的图像 1,1
    • Battery will be free to be removed and replaced.
结论
10等其他人完成本指南。
Noah Franklin
于10/27/15注册
445 声望
创作了5篇指南
团队
UMass Dartmouth, Team 2-3, Shastany Fall 2015 UMass Dartmouth, Team 2-3, Shastany Fall 2015 的会员
UMASSD-SHASTANY-F15S2G3
3 名成员
创作了10篇指南
3条评论
Where can I get a replacement battery?
Jeremy Nocek - 回复
You can look on Ebay or Amazon. You can find it by searching the model number: ( FT603048P )
The costs are like $20-$30.
If you look on Ebay under: ( 3.7v 603048 ), you can get the same battery without the connector for like $5.
William Smith - 回复
hey i have a question, how i can repair the mute button? It does not work.
fiercecesar - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 35
总计 23,727
