本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide will take you step by step through the process of replacing the battery in the Palm Tungsten T3.
你所需要的
Unscrew the two Phillips #00 screws on either side of the device, on the sliding handwriting panel.
You should now be left with the front panel and the battery.
Gently disconnect the battery connector. It's very small and the pins are very delicate, so be careful not to bend it.
When you install the new battery, you may find it useful to secure it to the back casing with some blu-tack, double-sided tape or even a small amount of glue.
10等其他人完成本指南。
一条评论
The only thing I would add is before replacing the battery, be sure to backup your device since disconnecting the battery will do a total reset.
