跳转到主内容
加入维修社区 - 创建账户
Tungsten E Power Button Repair
你所需要的
    1. Tungsten E Power Button Repair, Tungsten E Disassembly: 步骤 1 中的图像 1,2 Tungsten E Power Button Repair, Tungsten E Disassembly: 步骤 1 中的图像 2,2
      • Remove the stylus and SD card.
      • Using a T5 torx screwdriver, remove all 4 back panel screws.
      • The screws are small and can be lost easily. Be sure to place them in a secure area.
      询问修复机器人
      添加评论
    2. Tungsten E Power Button Repair: 步骤 2 中的图像 1,3 Tungsten E Power Button Repair: 步骤 2 中的图像 2,3 Tungsten E Power Button Repair: 步骤 2 中的图像 3,3
      • Insert a plastic opening tool under the USB and power input slots.
      • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
      添加评论
    3. Tungsten E Power Button Repair: 步骤 3 中的图像 1,2 Tungsten E Power Button Repair: 步骤 3 中的图像 2,2
      • Your device may not have a screen protector. If not, you can move on to step four.
      • Remove the screen protector by lifting the hinge out of the plastic housing.
      • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
      询问修复机器人
      添加评论
    4. Tungsten E Power Button Repair: 步骤 4 中的图像 1,2 Tungsten E Power Button Repair: 步骤 4 中的图像 2,2
      • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
      • Using a spudger, unlock both sides of the flex connector block by pushing down.
      • Remove motherboard completely.
      • Metal washers may pop out of the device during this step
      询问修复机器人
      添加评论
    5. Tungsten E Power Button Repair: 步骤 5 中的图像 1,3 Tungsten E Power Button Repair: 步骤 5 中的图像 2,3 Tungsten E Power Button Repair: 步骤 5 中的图像 3,3
      • Remove buttons using fingers.
      • Gently flex frame to release screen from plastic frame.
      • Lift out screen.
      询问修复机器人
      添加评论
    6. Tungsten E Power Button Repair: 步骤 6 中的图像 1,1
      • Congratulations! You have successfully taken apart a Palm Tungsten E.
      询问修复机器人
      添加评论
    1. Tungsten E Power Button Repair, Tungsten E Power Button Repair: 步骤 7 中的图像 1,1
      询问修复机器人
      添加评论
    2. Tungsten E Power Button Repair: 步骤 8 中的图像 1,1
      • On the motherboard, find the power button near the upper right corner.
      • Check for disconnection of the power button.
      询问修复机器人
      添加评论
    3. Tungsten E Power Button Repair: 步骤 9 中的图像 1,1
      • Use soldering iron to reattach the damaged power button to the motherboard.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Kathleen Hix
于01/21/10注册
49 声望
创作了2篇指南
团队
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G22
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 29
总计 5,615
