当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Remove the stylus and SD card.
Using a T5 torx screwdriver, remove all 4 back panel screws.
The screws are small and can be lost easily. Be sure to place them in a secure area.
Your device may not have a screen protector. If not, you can move on to step four.
Remove the screen protector by lifting the hinge out of the plastic housing.
Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
Using a spudger, unlock both sides of the flex connector block by pushing down.
Remove motherboard completely.
Metal washers may pop out of the device during this step
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
