跳转到主内容
Tungsten E Disassembly
你所需要的
  1. Tungsten E Disassembly, Tungsten E Disassembly: 步骤 1 中的图像 1,2 Tungsten E Disassembly, Tungsten E Disassembly: 步骤 1 中的图像 2,2
    • Remove the stylus and SD card.
    • Using a T5 torx screwdriver, remove all 4 back panel screws.
    • The screws are small and can be lost easily. Be sure to place them in a secure area.
  2. Tungsten E Disassembly: 步骤 2 中的图像 1,3 Tungsten E Disassembly: 步骤 2 中的图像 2,3 Tungsten E Disassembly: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool under the USB and power input slots.
    • Slide the plastic opener along the seam and gently pry the cover from the PDA body to remove the cover completely.
    I think it's better to open from the right, not the left. The right will separate if you lever the metal back to the outside and push the plastic to the inside. The lft is more like a inge and would damage more easily.
    Just my $0.02.
    Yishai Sered - 回复
  3. Tungsten E Disassembly: 步骤 3 中的图像 1,2 Tungsten E Disassembly: 步骤 3 中的图像 2,2
    • Your device may not have a screen protector. If not, you can move on to step four.
    • Remove the screen protector by lifting the hinge out of the plastic housing.
    • Remove the top cover by gently pulling it away from the device with a plastic opening tool or your fingers.
  4. Tungsten E Disassembly: 步骤 4 中的图像 1,2 Tungsten E Disassembly: 步骤 4 中的图像 2,2
    • Carefully remove motherboard from the standoffs without damaging the LCD flex connector.
    • Using a spudger, unlock both sides of the flex connector block by pushing down.
    • Remove motherboard completely.
    • Metal washers may pop out of the device during this step
  5. Tungsten E Disassembly: 步骤 5 中的图像 1,3 Tungsten E Disassembly: 步骤 5 中的图像 2,3 Tungsten E Disassembly: 步骤 5 中的图像 3,3
    • Remove buttons using fingers.
    • Gently flex frame to release screen from plastic frame.
    • Lift out screen.
  6. Tungsten E Disassembly: 步骤 6 中的图像 1,1
    • Congratulations! You have successfully taken apart a Palm Tungsten E.
结论
Kevin Hom
于01/21/10注册
103 声望
创作了2篇指南
团队
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G22
4 名成员
创作了4篇指南
一条评论
How does one unplug the battery?
dlcatftwin - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 7,789
