介绍
This is a repair guide for battery replacement.
  1. To reach the battery, follow steps 1 through 3 in the Tungsten E Teardown
  2. Begin to pry up the battery.  It is fastened to the mother board using two sided tape.
    • Begin to pry up the battery. It is fastened to the mother board using two sided tape.
    • Caution: the battery is connected by two wires.
  3. Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
    Android 维修工具包
    一个新的屏幕或电池就在一个套件之内。
    现在开始购物
  4. Remove the battery
    • Remove the battery
    • Caution: Be careful not to tear the wires when removing battery.
  5. Using a soldering iron, disconnect the battery wires.
    • Using a soldering iron, disconnect the battery wires.
    • Note: the wires are soldered to the board.
  6. Take replacement battery and solder the wires to the board.
    • Take replacement battery and solder the wires to the board.
    • Take care to match wire colors as before.
    • Use double sided tape to attach battery firmly to board.
结论
另外一个人完成了本指南。
Kathleen Hix
于2010年01月21日注册
49 Reputation
创作了2篇指南
Cal Poly, Team 13-22, Maness Winter 2010 Cal Poly, Team 13-22, Maness Winter 2010 的会员
CPSU-MANESS-W10S13G22
4 名成员
创作了4篇指南
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 5,809
