跳转到主内容
Tubeless Conversion for Gotway Begode Mten3 electric unicycle
你所需要的
  1. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove bezel: 步骤 1 中的图像 1,2 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove bezel: 步骤 1 中的图像 2,2
    • The two bezel pieces are each secured by a pair of hooks at the bottom of the wheel well. Pry to lift the hook by pushing the bezel toward the top of the machine (forward in the photo), rather than prying the bezel away from the machine.
  2. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove all edge screws: 步骤 2 中的图像 1,1
    • Remove the four edge screws with a #1 Phillips screwdriver. Turn the Mten3 over. Remove the additional four edge screws.
  3. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove Left Foot Pedal: 步骤 3 中的图像 1,2 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove Left Foot Pedal: 步骤 3 中的图像 2,2
    • Lay the machine left-side-up (anti-spin switch facing up)
    • Remove the two 5mm hex Allen set screws, one at each end of the left foot pedal
    • Use the Allen tool to push the hinge pin in so it protrudes at the other end, and then remove the hinge pin
    • Set aside the foot pedal, Allen screws, spacers, and hinge pin
  4. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove left shell mounting screws: 步骤 4 中的图像 1,1
    • Remove the screws that mount the left half-shell of the housing to the motor.
    • This may require you to remove the pad. To explain the photo, I installed a jump pad home-made from exercise mat. I used a small magnet to locate the closure magnet for reference, and an awl to locate the screws and then punch access holes.
  5. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Deflate the inner tube completely: 步骤 5 中的图像 1,1
    • Use a removal tool to remove the Schrader valve core to relieve the inner tube of any remaining pressure.
  6. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Detatch the light strip: 步骤 6 中的图像 1,1
    • Detatch the LED strip starting at the back of the Mten3.
    • You will not be unplugging the strip, so be careful it won't be damaged. For example you could temporarily tape it to the right half-shell of the vehicle
  7. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove left half-shell of case: 步骤 7 中的图像 1,1
    • Open the case, starting at the wheel well. If you have followed this procedure before, you will need to tear the seal above the wheel well.
    • If the case is not opening easily, be certain a screw is not still engaged.
  8. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Electrical Safety: 步骤 8 中的图像 1,2 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Electrical Safety: 步骤 8 中的图像 2,2
    • Once you open the case, the electrical components will be relatively exposed. The battery has enough voltage to shock you. Foreign objects (FOD), dripping sweat, dropped tools, pulled connector mates and cable ends, or flexed wires could have unintended consequences including malfunction of safety features.
    • Lay the halves of the case open side by side so that the wiring for the anti-spin-out switch is slack
    • Disconnect the battery. Cover the battery connector, for example with tape or a small plastic bag.
    • Cover the battery and controller with a shop rag or towel.
  9. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove the tire (zip tie method): 步骤 9 中的图像 1,3 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove the tire (zip tie method): 步骤 9 中的图像 2,3 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Remove the tire (zip tie method): 步骤 9 中的图像 3,3
    • The zip-tie method should allow you to remove the tire entirely, without using tools.
    • Thread at least five zip ties between the rim and the tube/tire, all the way through the channel, equally spaced around the rim.
    • For each zip tie, press the two tire beads together, with the tube inside the tire. Snug the zip tie so the beads are held closed together. This will allow the beads to drop into the channel at the center of the wheel.
    • It is now possible to pull the tire off-center and work it over the rim. A flat-blade screwdriver can be used, but hand strength may be sufficient.
    • The zip ties can be salvaged by inserting a knife blade between the tongue and tail to disengage the ratchet of the zip-tie fastener.
  10. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Inspect and clean the bead of the rim: 步骤 10 中的图像 1,1
    • Inspect the inside of the wheel rim where the tire bead was seated, visually and by feel. Use sand-paper to remove any corrosion or gouges.
    • If the tire bead is damaged (for example because of using a screwdriver during tire removal), you will need a replacement tire.
  11. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Install a tire valve stem: 步骤 11 中的图像 1,3 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Install a tire valve stem: 步骤 11 中的图像 2,3 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Install a tire valve stem: 步骤 11 中的图像 3,3
    • Apply a non-corrosive non-solvent lubricant/sealant. I used Armor-Dilloz Bead Buddy because I had it, worked great. Dish detergent would probably work well enough. Don't use a grease like faucet lube as it won't ever set, and so the stem will spin when you tighten or loosen the cap.
    • Insert the stem from inside the wheel. Screw a valve extender onto the stem and use it to pull the stem until it pops into place.
    • Remove the valve core and set it aside.
  12. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Install the tire: 步骤 12 中的图像 1,3 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Install the tire: 步骤 12 中的图像 2,3 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Install the tire: 步骤 12 中的图像 3,3
    • If the bead of the original tire is not damaged, that tire can be used. Otherwise a replacement tire can be ordered for example from eWheels.
    • Seal and lubricate the bead. I used Bead Buddy. Dish detergent might be a ready alternative. Apply to the bead area of both sides of the tire. Apply to the bead area inside both sides of the wheel.
    • Prepare the tire for installation by cinching the beads together using zip ties.
    • Slide the tire onto the wheel. This should be a fairly quick and easy manual operation.
    • Remove the zip ties.
  13. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Set the bead: 步骤 13 中的图像 1,1
    • The valve core is still removed. Using a hand-pump, inflate quickly and slightly over pressure. You may hear a popping noise as the bead drops into place, but I did not.
  14. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Add sealant and inflate tire: 步骤 14 中的图像 1,3 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Add sealant and inflate tire: 步骤 14 中的图像 2,3 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Add sealant and inflate tire: 步骤 14 中的图像 3,3
    • Add tire sealant as directed. I used 2 oz of Armor-Dilloz Red.
    • Reinstall the valve core
    • Reinflate the tire to 30 psi
  15. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Reassemble the case: 步骤 15 中的图像 1,2 Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Reassemble the case: 步骤 15 中的图像 2,2
    • Apply a bead of sealant at the top of the wheel well as a barrier to forceful water and dust penetration from the wheel well into the electrical power and electronics housing.
    • Silicone bathtub caulk is working for me. In my experience it is easily tearing loose when I need to open the case. I looked for some "H-channel" but couldn't find a source.
    • Do not clean the surfaces. Or treat at least one surface with a chemically compatible releaser like Armorall. This won't be the last tire you change, so you you want to fill the gap but not adhere permanently.
    • Mind the anti-spin switch wiring. Brand new my Mten3 had glitchy erratic behavior blamed on this wire being pinched at the factory.
    • Mind the alignment of the plastic fingers on the power panel.
    • Mind any other gaps that aren't closing or snapping together, they might be crushing wiring.
  16. Tubeless Conversion for Gotway Begode Mten3 electric unicycle, Check clearances: 步骤 16 中的图像 1,1
    • I used a black plastic valve cap to keep the debris out of the valve.
  17. Tubeless Conversion for Gotway Begode Mten3 electric unicycle: 步骤 17 中的图像 1,2 Tubeless Conversion for Gotway Begode Mten3 electric unicycle: 步骤 17 中的图像 2,2
    • Reassemble the shell, screws, foot pedal, LED strip, and bezel in reverse order of disassembly.
    • Perform an intermediate test at the first stage that is safe to do so.
    • Gear up (helmet, wrist guards, knee pads, elbow pads, all that) for a test ride.
结论
Student4Life
于05/27/17注册
2,613 声望
创作了7篇指南
一条评论
Thanks for the instructions!
Just want to add that I was told (by eWheels folks) that the tire from the Ninebot also fits on the MTEN3.
The tire from the Ninebot is available (for example here: https://www.ebay.com/itm/294319386406) whereas the tire from the MTEN3 is on backorder.
Julien Couvreur - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 15
总计 519
