跳转到主内容
Troy-Bilt TB675 EC Air Filter Replacement
你所需要的
  1. Troy-Bilt TB675 EC Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,1
    • Remove the air filter housing by turning the plastic screw counterclockwise with your hand.
  2. Troy-Bilt TB675 EC Air Filter Replacement, Remove the air filter that lays beneath the housing you removed in step 1: 步骤 2 中的图像 1,1
    • Remove the air filter that lays beneath the housing you removed in step 1.
    • It is good practice to inspect your air filter for tears or other defects. If defects are found it is best to replace the air filter rather than to clean it.
  3. Troy-Bilt TB675 EC Air Filter Replacement: 步骤 3 中的图像 1,1
    • Clean the air filter thoroughly by spraying compressed air through the filter.
    • Be sure to spray the compressed air away from you in order to prevent injury.
  4. Troy-Bilt TB675 EC Air Filter Replacement: 步骤 4 中的图像 1,2 Troy-Bilt TB675 EC Air Filter Replacement: 步骤 4 中的图像 2,2
    • Wipe all oil and water residue around the air filter casing with a paper towel or rag.
  5. Troy-Bilt TB675 EC Air Filter Replacement: 步骤 5 中的图像 1,1
    • Place the air filter and air filter casing back in its original position.
    • Be sure the air filter and housing are lined up correctly.
  6. Troy-Bilt TB675 EC Air Filter Replacement: 步骤 6 中的图像 1,1
    • Complete the maintenance by turning the screw clockwise with your hand until it is fully secured.
终点
Brian Hall
于10/10/14注册
110 声望
撰写一个指南
团队
USF Tampa, Team 1-10, Donnelly Fall 2014 USF Tampa, Team 1-10, Donnelly Fall 2014 的会员
USFT-DONNELLY-F14S1G10
1 名成员
创作了1篇指南
一条评论
I believe you may have missed the small detail of giving us a part #.
That would’ve been VERY helpful.
Mark Henry Cooney - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 36
总计 2,380
