跳转到主内容
Triplett ET200 AC Line Splitter Basic Outlet testing.
  1. Triplett ET200 AC Line Splitter Basic Outlet testing., Triplett ET200 AC Line Splitter Basic Outlet testing.: 步骤 1 中的图像 1,3 Triplett ET200 AC Line Splitter Basic Outlet testing., Triplett ET200 AC Line Splitter Basic Outlet testing.: 步骤 1 中的图像 2,3 Triplett ET200 AC Line Splitter Basic Outlet testing., Triplett ET200 AC Line Splitter Basic Outlet testing.: 步骤 1 中的图像 3,3
    • To check outlet wiring, we use the chart on the back and this device works like any other outlet tester
    • Plug the device in and read the lights based on the chart. (Please note that in my image, the actual test shows the normal lights on the right verses the left as reading the chart. This is due to the outlet orientation)
    • If you get the 2 orange lights, then your outlet is wired correctly. Otherwise if you have different or no lights, see the chart for where to look for the problem.
    • You are done testing your outlet. If your outlet is not correct, please do not try to correct it without a good understanding of house wiring standards and make sure to turn the power off before opening up an outlet.
结论
Testing your home outlets is easy with the correct electric testers.
另外一个人完成了本指南。
rickwag
于10/18/10注册
1,602 声望
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 90
