跳转到主内容
加入维修社区 - 创建账户
Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement
你所需要的
  1. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Back Panel: 步骤 1 中的图像 1,1
    • To remove the back panel, you will need to use a plastic opening tool and slowly separate the back panel from the device.
  2. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement, Front-Facing/ Rear-Facing Camera: 步骤 2 中的图像 1,1
    • Next use your PH 0 to remove the two 4mm screws to detach the camera support fixture.
  3. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: 步骤 3 中的图像 1,1
    • Disconnect the camera from the mother board. Use a spudger and lift the grey latch until it is facing up then pull out the connection for the cameras.
  4. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the first layer of tape above camera cable connection slowly.
  5. Trio Stealth-10 Front-Facing/Rear-Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Remove the second layer of tape above camera cable connection gently and remove the cameras from the device.
结论
2等其他人完成本指南。
Daniel Coleman
于10/29/15注册
643 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-4, Miles Fall 2015 UMass Dartmouth, Team 1-4, Miles Fall 2015 的会员
UMASSD-MILES-F15S1G4
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 520
