跳转到主内容
Trio Stealth Pro 9.7" Rear/Front Camera Replacement
你所需要的
  1. Trio Stealth Pro 9.7" Rear/Front Camera Replacement, Rear/Front Camera: 步骤 1 中的图像 1,1
    • Remove 2 black 4 cm Phillips screws on either side of the bottom of the device.
  2. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: 步骤 2 中的图像 1,2 Trio Stealth Pro 9.7" Rear/Front Camera Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tools and the spudger around the outside of silver metal back plate on the device to pry off the back plate.
  3. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: 步骤 3 中的图像 1,3 Trio Stealth Pro 9.7" Rear/Front Camera Replacement: 步骤 3 中的图像 2,3 Trio Stealth Pro 9.7" Rear/Front Camera Replacement: 步骤 3 中的图像 3,3
    • Use plastic opening tool to lift up black clip.
    • Gently pull out flex cable.
  4. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: 步骤 4 中的图像 1,1
    • Remove 3 silver 4 cm Phillips screws holding down black plastic speaker cover.
    • Gently pull up on plastic to uncover clip connected to the camera.
  5. Trio Stealth Pro 9.7" Rear/Front Camera Replacement: 步骤 5 中的图像 1,2 Trio Stealth Pro 9.7" Rear/Front Camera Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers and gently lift up on the clip.
    • Remove the front/rear camera.
结论
2等其他人完成本指南。
Edward Insogna
于03/23/15注册
626 声望
创作了5篇指南
团队
UMass Dartmouth, Team 1-3, Miles Spring 2015 UMass Dartmouth, Team 1-3, Miles Spring 2015 的会员
UMASSD-MILES-S15S1G3
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 164
