简介
If your Trio Stealth Pro 9.7" tablet is having issues charging or is experiencing a shorter battery life, it may be necessary to change the tablet's battery. Overtime, tablet batteries can degrade and lose their ability to hold a charge. This guide will provide step- by-step instructions of the process of removing the old battery and replacing it with a new one. It is important to carefully follow these instructions to prevent damaging the tablet.
Before using this guide, it is important to ensure the tablet is unplugged from any charging cords and is powered off. You will need to have a small screwdriver, a plastic opening tool, and a spudder. It is necessary to pay attention to detail and to follow these instructions very carefully to avoid any potential damage to the device. It also may be helpful to see if your tablet has a warranty because some warranties cover battery issues and a professional will fix the issue for you.
Even though this is a pretty simple technical procedure, there are still some risks with completing this repair. Improper handling of the battery could lead to device damage or create an electrical short circuit. Make sure you don't apply excessive amounts of force to the tablet and work in a clean dry environment.
你所需要的
2等其他人完成本指南。
