跳转到主内容
Trio Stealth G2 Hype Back Panel Replacement
你所需要的
  1. Trio Stealth G2 Hype Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,2 Trio Stealth G2 Hype Back Panel Replacement, Back Panel: 步骤 1 中的图像 2,2
    • Remove the two 1.2 mm Phillips #0 screws found at the side by the power button.
  2. Trio Stealth G2 Hype Back Panel Replacement: 步骤 2 中的图像 1,1
    • Using the plastic opening tool, insert it between the back panel and screen starting on the corner to the right of the power button side and begin separating the back cover.
    • Be cautious when opening the back cover as it is connected through fragile wires to the speaker.
  3. Trio Stealth G2 Hype Back Panel Replacement: 步骤 3 中的图像 1,3 Trio Stealth G2 Hype Back Panel Replacement: 步骤 3 中的图像 2,3 Trio Stealth G2 Hype Back Panel Replacement: 步骤 3 中的图像 3,3
    • Remove the speakers by using your hand to entirely disconnect the back cover.
结论
团队
USF Tampa, Team 4-4, Brown Winter 2015 USF Tampa, Team 4-4, Brown Winter 2015 的会员
USFT-BROWN-W15S4G4
3 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 681
