跳转到主内容
加入维修社区 - 创建账户
Trio STEALTH-9 Speaker Replacement
你所需要的
  1. Trio STEALTH-9 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Remove the two Phillips #00 screws on the side of the tablet.
    询问修复机器人
    添加评论
  2. Trio STEALTH-9 Speaker Replacement: 步骤 2 中的图像 1,1
    • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
    • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
    询问修复机器人
    添加评论
  3. Trio STEALTH-9 Speaker Replacement: 步骤 3 中的图像 1,1
    • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
    • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
    询问修复机器人
    添加评论
  4. Trio STEALTH-9 Speaker Replacement: 步骤 4 中的图像 1,1
    • Remove the back cover of the tablet to reveal the internals.
    • To replace, pinch each of the ends together until all four sides are closed.
    询问修复机器人
    添加评论
  5. Trio STEALTH-9 Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Slowly remove the electrical tape holding down the Speaker wires.
    询问修复机器人
    添加评论
  6. Trio STEALTH-9 Speaker Replacement: 步骤 6 中的图像 1,2 Trio STEALTH-9 Speaker Replacement: 步骤 6 中的图像 2,2
    • Remove the #00 screw on the Speaker mount and remove the Speaker mount.
    询问修复机器人
    添加评论
  7. Trio STEALTH-9 Speaker Replacement: 步骤 7 中的图像 1,1
    • Prepare your Soldering tools. Desolder the Speaker leads from the Motherboard.
    • Remove any excess solder as necessary, and apply new solder when replacing a Speaker.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order, making sure to be careful with your wiring leads and soldering work.
取消:我没有完成这个指南。
[deleted]
于01/29/15注册
415 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 30
总计 455
