简介
Here, you will be taking apart your device so that you will have access to the speaker on your Trio. For the following steps, you must be very careful with some of the wires because of how thin they are, and you will be using soldering tools for this process as well.
你所需要的
即将完成!
To reassemble your device, follow these instructions in reverse order, making sure to be careful with your wiring leads and soldering work.
结论
