跳转到主内容
加入维修社区 - 创建账户
Trio STEALTH-9 Motherboard Replacement
浏览量: 1161
浏览统计数据:
过去24小时
4
过去 7 天:
20
过去 30 天:
89
总计
1,161
评论: 0
暂时还没有人对本指南发表评论。你想做第一个评论的人吗?
Go to guide comments
已完成: 2
2 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 20分钟 - 1小时
难度: 困难
This Motherboard you will be fixing/replacing will contain sensitive electronic parts, so be very careful!
你所需要的
工具
    1. Trio STEALTH-9 Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Remove the two Phillips #00 screws on the side of the tablet.
      询问修复机器人
      添加评论
    2. Trio STEALTH-9 Motherboard Replacement: 步骤 2 中的图像 1,1
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      询问修复机器人
      添加评论
    3. Trio STEALTH-9 Motherboard Replacement: 步骤 3 中的图像 1,1
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      询问修复机器人
      添加评论
    4. Trio STEALTH-9 Motherboard Replacement: 步骤 4 中的图像 1,1
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      询问修复机器人
      添加评论
    1. Trio STEALTH-9 Motherboard Replacement, Battery: 步骤 5 中的图像 1,1
      • With the cover removed, slowly pull the electrical tape away as shown.
      询问修复机器人
      添加评论
    2. Trio STEALTH-9 Motherboard Replacement: 步骤 6 中的图像 1,1
      • Slowly pull the Battery away from the tablet frame.
      询问修复机器人
      添加评论
    3. Trio STEALTH-9 Motherboard Replacement: 步骤 7 中的图像 1,1
      • Prepare your Soldering Iron and Removal Tools.
      • Contact the iron with each of the battery leads, and pull the lead away from the board.
      • Remove any excess solder as needed.
      询问修复机器人
      添加评论
    4. Trio STEALTH-9 Motherboard Replacement: 步骤 8 中的图像 1,1
      • To replace your battery, you must reinsert the Battery leads into the Motherboard, being sure that the Red wire goes into the + (positive) terminal and the Black wire goes into the - (negative) terminal.
      • Apply heat and solder to each lead individually.
      • Remove any excess solder if flooding occurs.
      询问修复机器人
      添加评论
    1. Trio STEALTH-9 Motherboard Replacement, Camera: 步骤 9 中的图像 1,2 Trio STEALTH-9 Motherboard Replacement, Camera: 步骤 9 中的图像 2,2
      • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
      询问修复机器人
      添加评论
    2. Trio STEALTH-9 Motherboard Replacement: 步骤 10 中的图像 1,2 Trio STEALTH-9 Motherboard Replacement: 步骤 10 中的图像 2,2
      • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
      询问修复机器人
      添加评论
    3. Trio STEALTH-9 Motherboard Replacement: 步骤 11 中的图像 1,2 Trio STEALTH-9 Motherboard Replacement: 步骤 11 中的图像 2,2
      • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
      • Remove the camera from the frame and replace as needed.
      询问修复机器人
      添加评论
    1. Trio STEALTH-9 Motherboard Replacement, Speaker: 步骤 12 中的图像 1,1
      • Slowly remove the electrical tape holding down the Speaker wires.
      询问修复机器人
      添加评论
    2. Trio STEALTH-9 Motherboard Replacement: 步骤 13 中的图像 1,2 Trio STEALTH-9 Motherboard Replacement: 步骤 13 中的图像 2,2
      • Remove the #00 screw on the Speaker mount and remove the Speaker mount.
      询问修复机器人
      添加评论
    3. Trio STEALTH-9 Motherboard Replacement: 步骤 14 中的图像 1,1
      • Prepare your Soldering tools. Desolder the Speaker leads from the Motherboard.
      • Remove any excess solder as necessary, and apply new solder when replacing a Speaker.
      询问修复机器人
      添加评论
    1. Trio STEALTH-9 Motherboard Replacement, Motherboard: 步骤 15 中的图像 1,1
      • Prepare your Desoldering Tools. Remove the grey wire attached to the Motherboard.
      询问修复机器人
      添加评论
    2. Trio STEALTH-9 Motherboard Replacement: 步骤 16 中的图像 1,3 Trio STEALTH-9 Motherboard Replacement: 步骤 16 中的图像 2,3 Trio STEALTH-9 Motherboard Replacement: 步骤 16 中的图像 3,3
      • Remove the three #00 Screws holding down the Motherboard.
      询问修复机器人
      添加评论
    3. Trio STEALTH-9 Motherboard Replacement: 步骤 17 中的图像 1,2 Trio STEALTH-9 Motherboard Replacement: 步骤 17 中的图像 2,2
      在这个步骤中使用的工具:
      • Use a pair of Tweezers to carefully pull the side buttons away from the frame.
      • Use the same Tweezers to carefully pull the microphone away from the front of the frame.
      询问修复机器人
      添加评论
    4. Trio STEALTH-9 Motherboard Replacement: 步骤 18 中的图像 1,3 Trio STEALTH-9 Motherboard Replacement: 步骤 18 中的图像 2,3 Trio STEALTH-9 Motherboard Replacement: 步骤 18 中的图像 3,3
      • Use your fingernails or a plastic opening tool to remove any remaining ribbon cables from the Motherboard.
      询问修复机器人
      添加评论
    5. Trio STEALTH-9 Motherboard Replacement: 步骤 19 中的图像 1,1
      • With the cables removed, lift the Motherboard off of the frame.
      • Repair or replace the Motherboard as needed.
      询问修复机器人
      添加评论
结论
To reassemble your device, follow these instructions in reverse order while being careful with the electronics on your repaired/replaced Motherboard.
取消:我没有完成这个指南。
2等其他人完成本指南。
Mei Liang
于01/29/15注册
228 声望
创作了2篇指南
团队
Clemson, Team 15-5, Shirley Winter 2015 Clemson, Team 15-5, Shirley Winter 2015 的会员
CLEM-SHIRLEY-W15S15G5
4 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 89
总计 1,161
