跳转到主内容
加入维修社区 - 创建账户
Trio STEALTH-9 Camera Replacement
你所需要的
    1. Trio STEALTH-9 Camera Replacement, Back Cover: 步骤 1 中的图像 1,1
      • Remove the two Phillips #00 screws on the side of the tablet.
      询问修复机器人
      添加评论
    2. Trio STEALTH-9 Camera Replacement: 步骤 2 中的图像 1,1
      • Take one of the plastic opening tools and wedge it in the middle of the tablet, starting on the USB Port side.
      • Holding the tool in place, take one of the 6 plastic opening picks and slide it across the opening you made with the opening tool.
      询问修复机器人
      添加评论
    3. Trio STEALTH-9 Camera Replacement: 步骤 3 中的图像 1,1
      • Continue going around the tablet sides with the plastic pick, being sure that you are maintaining the openings you made with either your hand or the opening tool.
      • You will notice some popping as you go around with the pick. Don't worry, this is completely normal.
      询问修复机器人
      添加评论
    4. Trio STEALTH-9 Camera Replacement: 步骤 4 中的图像 1,1
      • Remove the back cover of the tablet to reveal the internals.
      • To replace, pinch each of the ends together until all four sides are closed.
      询问修复机器人
      添加评论
    1. Trio STEALTH-9 Camera Replacement, Camera: 步骤 5 中的图像 1,2 Trio STEALTH-9 Camera Replacement, Camera: 步骤 5 中的图像 2,2
      • Slowly remove the two pieces of electrical tape holding down the Camera ribbon cable.
      询问修复机器人
      添加评论
    2. Trio STEALTH-9 Camera Replacement: 步骤 6 中的图像 1,2 Trio STEALTH-9 Camera Replacement: 步骤 6 中的图像 2,2
      • Remove the #00 Screw holding down the Camera mount, then remove the Camera mount.
      询问修复机器人
      添加评论
    3. Trio STEALTH-9 Camera Replacement: 步骤 7 中的图像 1,2 Trio STEALTH-9 Camera Replacement: 步骤 7 中的图像 2,2
      • Detach the Camera's ribbon cable from the Motherboard using your fingernail or a plastic opening tool.
      • Remove the camera from the frame and replace as needed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
[deleted]
于01/29/15注册
415 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 25
过去 30 天: 45
总计 478
