跳转到主内容
Trio AXS 3G Speaker Replacement
你所需要的
  1. Trio AXS 3G Speaker Replacement, Back Case: 步骤 1 中的图像 1,1
    • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
    • Use your thumbs to slide up and off the small SD card case.
  2. Trio AXS 3G Speaker Replacement: 步骤 2 中的图像 1,2 Trio AXS 3G Speaker Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
  3. Trio AXS 3G Speaker Replacement: 步骤 3 中的图像 1,1
    • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
    • Do not pry too hard as the screen is fragile and might crack.
    • It is best to start at the bottom of the tablet when prying the back panel off.
    • The volume piece will also dislodge when the back panel is removed.
  4. Trio AXS 3G Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • Unscrew the two 4 mm #000 screws.
  5. Trio AXS 3G Speaker Replacement: 步骤 5 中的图像 1,1
    • Use a soldering iron to desolder the speaker connection.
    • Be careful not to melt the wires.
  6. Trio AXS 3G Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the speaker.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 181
