跳转到主内容
加入维修社区 - 创建账户
Trio AXS 3G Back Case Replacement
你所需要的
    1. Trio AXS 3G Back Case Replacement, Back Case: 步骤 1 中的图像 1,1
      • On the back of the device there is a white SD card case that shelters the screws that attach the back panel to the tablet.
      • Use your thumbs to slide up and off the small SD card case.
      询问修复机器人
      添加评论
    2. Trio AXS 3G Back Case Replacement: 步骤 2 中的图像 1,2 Trio AXS 3G Back Case Replacement: 步骤 2 中的图像 2,2
      • Using the Phillips Head #000, unscrew the 5 4mm and 3mm screws at the top.
      询问修复机器人
      添加评论
    3. Trio AXS 3G Back Case Replacement: 步骤 3 中的图像 1,1
      • Insert a plastic opening tool between the back panel and the front of the tablet, and gently pry it away from the tablet.
      • Do not pry too hard as the screen is fragile and might crack.
      • It is best to start at the bottom of the tablet when prying the back panel off.
      • The volume piece will also dislodge when the back panel is removed.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 37
总计 687
