跳转到主内容
Tribit XSound Go TS-BTS20 Battery Replacement
你所需要的
  1. Tribit XSound Go TS-BTS20 Battery Replacement, Battery: 步骤 1 中的图像 1,2 Tribit XSound Go TS-BTS20 Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Insert a spudger in the seam between the front speaker grill and chassis.
    • Pry around the perimeter until the front grill releases.
    • Remove the front grill.
  2. Tribit XSound Go TS-BTS20 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the 14 Phillips screws around the perimeter of the speaker.
    • Lift off the speaker housing.
  3. Tribit XSound Go TS-BTS20 Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Disconnect the white speaker connections by gently pulling up with tweezers.
  4. Tribit XSound Go TS-BTS20 Battery Replacement: 步骤 4 中的图像 1,1
    • Find the battery cover.
    • Use a screwdriver to unscrew the sides of the covering.
  5. Tribit XSound Go TS-BTS20 Battery Replacement: 步骤 5 中的图像 1,1
    • Pull the covering up with a pair of tweezers.
  6. Tribit XSound Go TS-BTS20 Battery Replacement: 步骤 6 中的图像 1,1
    • Disconnect the batteries by pulling the battery connectors directly out of their motherboard ports.
  7. Tribit XSound Go TS-BTS20 Battery Replacement: 步骤 7 中的图像 1,1
    • Gently pull the batteries out of the speaker.
结论
另外一个人完成了本指南。
2条评论
I couldn't find online the exact battery replacement, any suggestions?
fred - 回复
Same here. What is the replacement battery number?
jay.8garrison@gmail.com - 回复
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 52
过去 30 天: 223
总计 981
