跳转到主内容
Triace A310 Tire Disassembly
  1. Triace A310 Tire Disassembly, Tire: 步骤 1 中的图像 1,1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Tire Disassembly: 步骤 2 中的图像 1,2 Triace A310 Tire Disassembly: 步骤 2 中的图像 2,2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Tire Disassembly: 步骤 3 中的图像 1,2 Triace A310 Tire Disassembly: 步骤 3 中的图像 2,2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
结论
To reassemble your device, please follow these steps in reverse order.
Daniel
于01/27/14注册
222 声望
创作了2篇指南
团队
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G37
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 469
