危险
有潜在危险
如果不正确地执行这个步骤,就可能导致受伤。请保持谨慎并注意所有警告。
危险
简介
In order to have a safer biking experience, make sure your disk brake is properly replaced.
配件
无需配件。
  1. Begin loosening the tire by turning the quick release handle.
    • Begin loosening the tire by turning the quick release handle.
  2. Gripping the rear derailleur, pull the arm back, away from the front of the bike. Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. There should be enough slack, in the chain, at this point to remove the tire from the bike. Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  5. Place the tire  flat on the ground making sure the disk is facing you.
    • Place the tire flat on the ground making sure the disk is facing you.
  6. Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws. Make sure to keep track of all of the removed pieces. Make sure to keep track of all of the removed pieces.
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  7. After all of the screws have been removed, take the disk and pull it away from the tire. After all of the screws have been removed, take the disk and pull it away from the tire.
    • After all of the screws have been removed, take the disk and pull it away from the tire.
结论
Daniel
于2014年01月27日注册
222 信誉积分
创作了2篇指南
团队
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G37
4 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 331
