跳转到主内容
Triace A310 Brake Pad Replacement
你所需要的
  1. Triace A310 Brake Pad Replacement, Brake Pad: 步骤 1 中的图像 1,2 Triace A310 Brake Pad Replacement, Brake Pad: 步骤 1 中的图像 2,2
    • Note: In this repair guide the pictures are taken with the tire removed so that it is easier to follow our steps. However, removing the tire is not necessary to replace the brake pads.
    • Unscrew the brake pad cap with a T25 screwdriver bit.
  2. Triace A310 Brake Pad Replacement: 步骤 2 中的图像 1,3 Triace A310 Brake Pad Replacement: 步骤 2 中的图像 2,3 Triace A310 Brake Pad Replacement: 步骤 2 中的图像 3,3
    • Grab and pull out the spring between the brake pads.
  3. Triace A310 Brake Pad Replacement: 步骤 3 中的图像 1,3 Triace A310 Brake Pad Replacement: 步骤 3 中的图像 2,3 Triace A310 Brake Pad Replacement: 步骤 3 中的图像 3,3
    • Slide out the back brake pad first. Then slide out the front brake pad.
  4. Triace A310 Brake Pad Replacement: 步骤 4 中的图像 1,2 Triace A310 Brake Pad Replacement: 步骤 4 中的图像 2,2
    • Slide in the new brake pads with the first going in the front.
  5. Triace A310 Brake Pad Replacement: 步骤 5 中的图像 1,3 Triace A310 Brake Pad Replacement: 步骤 5 中的图像 2,3 Triace A310 Brake Pad Replacement: 步骤 5 中的图像 3,3
    • Then slide in the other pad in the back.
    • Make sure each brake pad is facing the right way.
  6. Triace A310 Brake Pad Replacement: 步骤 6 中的图像 1,3 Triace A310 Brake Pad Replacement: 步骤 6 中的图像 2,3 Triace A310 Brake Pad Replacement: 步骤 6 中的图像 3,3
    • Push the spring back into place between the two brake pads so the spring is visible in the hole shown here.
  7. Triace A310 Brake Pad Replacement: 步骤 7 中的图像 1,2 Triace A310 Brake Pad Replacement: 步骤 7 中的图像 2,2
    • Screw the brake pad cap back on.
  8. Triace A310 Brake Pad Replacement: 步骤 8 中的图像 1,1
    • Adjust the red knob as necessary (directions are noted on the knob).
    • Be sure to test your brakes thoroughly in a safe, low-speed environment.
结论
Now your bike should actually be able to stop.
Ben Hartinger
于01/27/14注册
340 声望
创作了3篇指南
团队
Cal Poly, Team 1-37, Maness Winter 2014 Cal Poly, Team 1-37, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G37
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 388
